Hello, I’m writing because I want to put generated rss ( from fivefilter ) to my wordpress rss agregator (FeedWordpress Plugin). But I only get “feed not recognizable”. I think the URL provided by fivefilter
“eg: http://ftr.fivefilters.org/makefulltextfeed.php?url=http%3A%2F%2Fmukki.org%2Ftv%2Ffeed&max=3”
is not recognizable as feed url which is usually http://test.com/rss.xml or http://test.com/feed
Kindly shed some light to this problem.
Hi Max, I’m not familiar with that plugin, so not sure what the problem is. You might want to take it up with the plugin author.
If you want to see whether our feeds are valid, you can use http://feedvalidator.org - I just tried your URL and it returns as valid: http://feedvalidator.org/check.cgi?url=http%3A%2F%2Fftr.fivefilters.org%2Fmakefulltextfeed.php%3Furl%3Dhttp%3A%2F%2Fmukki.org%2Ftv%2Ffeed%26max%3D3 (as should all feeds generated by FiveFilters.org).
