Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
First article as no-title
Killol — Apr 01, 2017 07:35AM CEST
Why in some site first article title is shown as no-title?
1 Community Answers
Keyvan Minoukadeh - Apr 01, 2017 at 05:09PM CEST Agent
At the moment, the elements you're asking Feed Creator to select have more than one a element in them. The first one does not contain the headline, the second does. So it's not clear which one Feed Creator should select. We'll try to improve this in the future, ie. by trying to see if a more suitable element should be selected. But in these cases it's usually better to be more specific.
In the following, we use the item parameter to be more specific about which element it should look inside. You'll see that it now loads the first item correctly:
rated : 0 Up Down
Post Your Public Answer
