When saving as Epub, the reference to the stylesheet in the header points to directory “CSS” when it should point to “Styles”. Therefore the stylesheet is useless unless this reference is changed in the article head.
Thanks Patrick, we’ll look into this. Does this affect the display of the ebook for you? Or produce an error in your e-reader or reading app?
It turns out that it does point to the right folder (CSS) but the link is wrong. It points to book.css?v1. It should point to book.css
Patrick
