Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Problem with images
Query regarding viewing images — Mar 06, 2017 10:41AM CET
For a few feeds, even though Full Text is able to extract images perfectly when viewed from the browser, the moment I add the feed to a feed reader, the image fail to get imported.
There's no issue with the site config here since everything works perfectly with Full Text, but it's only when I use the feed on different feed readers that the images disappear.
3 Community Answers
Keyvan Minoukadeh - Mar 06, 2017 at 11:26AM CET Agent
Could you let us know which feed readers you've had this problem with? I'm not sure if there's anything we can do, but would be good to know. Have you tried contacting the feed reader developers?
rated : 0 Up Down
Arnab Das - Mar 08, 2017 at 07:41AM CET
The usual lot.
Miniflux, Selfoss, FreshRSS.
rated : 0 Up Down
Keyvan Minoukadeh - Mar 08, 2017 at 03:24PM CET Agent
Many feed readers rewrite the HTML in feeds for display purposes. I wonder if the image elements we're returning need to be changed in some situations. If you have examples of the HTML that's causing the problem, please let us know and we'll take a look.
rated : 0 Up Down
Post Your Public Answer
