Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Full article not sent
Bryony — Feb 10, 2017 12:50AM CET
When pushing an article to kindle , only half it gets sent
I'd like to send the full article if possible
Please help
1 Community Answers
Keyvan Minoukadeh - Feb 10, 2017 at 01:14AM CET Agent
Hi Bryony, can you tell us which article you're trying to send? We might be able to improve the extraction rules to make sure the whole thing gets processed (it usually does, but some sites might need additional rules). You can also email us at if you prefer.
rated : 1 Up Down
Post Your Public Answer
