Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
images in preview and pdf but not in mobi/epub
aifol — Nov 23, 2016 08:16PM CET
I tried different webpages and the pictures are shown in the preview and in a generated pdf, but are not embedded in the mobi or epub files (readed on a kindle 2014 or the reader from Calibre software).
I know that not all webpages are working but I guess the fact I didn't find a working one is not normal. Is it supposed to work if the pictures are shown in the preview ? If not do you have an URL which works with certainty to know if the problem occurs from my side ?
(Tried with Firefox and Opera extensions, works fine with pictures with the Amazon extension but I would rather use yours)
2 Community Answers
Keyvan Minoukadeh - Nov 24, 2016 at 07:31PM CET Agent
Hi there, sorry about that. We have separate servers which handle image processing and sometimes they go down. If that happens, images will appear in the preview, but not when the actual epub/mobi files get generated. The servers should be back up now. We're working on fixing the downtime issues.
Thanks for reporting this, and sorry for the inconvenience.
rated : 1 Up Down
aifol - Dec 04, 2016 at 12:02PM CET
Works fine now indeed, thanks.
rated : 0 Up Down
Post Your Public Answer
