Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Example of using inputhtml
M Ridwan Agustiawan — Nov 01, 2016 07:17AM CET
Thanx for this great product. Definitely worth of my money.
By the way, I found in http://blog.fivefilters.org/post/85623859647/full-text-rss-33 that I can use inputhtml parameter.
I tried it using postman to simulate it but failed. Input parameters as follows:
url: https://www.infokomputer.com/2015/08/best-apps/android/timehop/
format: json
inputhtml: *the html from the above url*
Could you tell and give me an example how to use it?
1 Community Answers
Keyvan Minoukadeh - Nov 02, 2016 at 03:11PM CET
FiveFilters.org Agent
Hi there, can you provide a little more information on what you tried? Where did you send the request to? Which HTTP request method did you use? What were the other parameters?
You're welcome to try the form available at Mashape to play around with this:
https://market.mashape.com/fivefilters/full-text-rss
rated : 0 Up Down
Post Your Public Answer
