Why is it that when using the RSS feed with excerpt option it only retrieves last 3 articles but when just using RSS headlines it retrieves all previous 10? Is there a way to retrieve all 10 using excerpt option as well?
Hi Grant, When you use the regular output, you’re only relying on Feed Creator. When requesting excerpts, the Feed Creator results are passed to Full-Text RSS. In our hosted service, this returns only 3 items (to reduce server load). If you buy the self-hosted package, you can change this limit to return more (the default is 5 or 10 items in the self-hosted package).
